Help me in these images is this problem on my video card?
  • medo_h_e
    • Mar 2011
    on my video card sapphire 5670 HD 1GB
    i see some problems on my card i dont know if this problem from my card or my display or in catalyst setting
    problems show on many games like gta iv eflc and nfs hot persuit
    these are images for problem
    First image on gta iv
    second on nfs hot persuit 2
    Looks like you have anti-aliasing off or too low.
    Check the setting in the games and in you video card device driver.
    There is a good comparison image here,
    http://www.tweakguides.com/images/Antialiasing.gif
    • medo_h_e
      • Mar 2011
      My Spec>
      Win XP SP3
      CPU : AMD athlon 64 X2 Dual Core 5000+ 2.6 Ghz
      Ram : 2GB Transend DDR2 800
      MotherBoard : Gigabyte GA-MA74GM-S2
      Video Card : Sapphire 5670 HD 1GB
      Power Supply : HEC 350 Watt
      Display : CRT DELL 17"
      • medo_h_e
        • Mar 2011
        ok but AA is turned on From Catalyst Controller and nothing happend
        • medo_h_e
          • Mar 2011
          ok thanks for all
          i knew that GTA IV not use AA or AF and nfs hot pursuit too
          thanks again
