My GPU is extremely low score !!!!
  • KochiroKagehara
    • Nov 2016
    http://www.passmark.com/baselines/V9...id=70630629764
    Here is my PC's general information, i don't know why, it must be around 6000 but my VGA just only 2000 ....
    See this post to start with,
    • KochiroKagehara
      • Nov 2016
      After reinstall the lasted driver nVidia 375.70 and using DirectX the performance isn't getting better but it down to 1800 ....
        Well you are running Win7, which doesn't support DirectX 12, but you have a new DirectX 12 video card. So that isn't helping the result.
        The seven year old dual core CPU you have is also under powered, which hurts the 3D tests which run a lower resolutions (the lower the resolution the higher the load on the CPU).
        • KochiroKagehara
          • Nov 2016
          I see, your points are right, i will consider it , because i buy the VGA for my next PC ; But i'm not building it now maybe 2 or 3 month later, thank you for your advice, that helps a lot
          • i7Baby
            • Aug 2012
            • 62
            Also the old i3 will bottleneck the gtx1050Ti
