Does A power connector on gpu really matter
  • GTX 1050 Ti
    • Dec 2016
    • 46
    I have a gtx 1050 ti with now power cable, Does a power cable really make any difference
    You either need it or you don't.
    From Wikipedia,
    All sizes of PCIe ×16 cards are initially 25 W; half-height cards are limited to this number while full-height cards may increase their power after configuration. They can use up to 75 W (3.3 V×3 A + 12 V×5.5 A), though the specification demands that the higher-power configuration be used for graphics cards only, while cards of other purposes are to remain at 25 W.
    So if your card doesn't use more than 75W, then no extra power connection is required.
    Probably means overclocking will break the PCIe standards however. Some motherboards will be OK with this. Some might not be.
    • GTX 1050 Ti
      • Dec 2016
      • 46
      I mean like, Gtx 1050 ti without power connector vs gtx 1050 ti with power connector, does it matter?
        There should be more overclocking potential with an additional power connector.
        But not needing a connector means more compatibility with low end machines with low end power supplies.
        • GTX 1050 Ti
          • Dec 2016
          • 46
          Ok, because last time i have a pwoer cable run into my graphics card a capacitor on the graphics card blew up :P
            Faults happen sometimes. I don't think the wattage of a video card is a good indication of the probability of failure.
            • GTX 1050 Ti
              • Dec 2016
              • 46
              Would it be because of a psu?
                Most likely cause of a capacitor blowing up is that it was a bad (or old) capacitor
