Need help with GPU bottleneck
  • Mangled
    • Jun 2012
    Hey everyone thanks in advance for taking time to check this thread. I just ran the passmark benchmark test for the first time and my issue is for the baseline comparison on the 3d tests for simple and medium surpass the others but for the complex 3d I am dropped to a score of 10. I've researched some other peoples scores on this forum and some have lower scores on the simple/medium, but higher on the complex. I am running the latest gpu drivers for my GeForce GTI 560 TI 2048mb. I'll post some of the scores below. Any help would be appreciated thanks.
    Test Name: This Computer
    CPU - Integer Math: 437.7
    CPU - Floating Point Math: 2625.2
    CPU - Find Prime Numbers: 756.2
    CPU - SSE: 14.3
    CPU - Compression: 3827.3
    CPU - Encryption: 17.1
    CPU - Physics: 174.2
    CPU - String Sorting: 2495.4
    Graphics 2D - Solid Vectors: 0.4
    Graphics 2D - Transparent Vectors: 0.6
    Graphics 2D - Complex Vectors: 108.3
    Graphics 2D - Fonts and Text: 156.6
    Graphics 2D - Windows Interface: 81.2
    Graphics 2D - Image Filters: 153.1
    Graphics 2D - Image Rendering: 269.6
    Graphics 3D - Simple: 1979.3
    Graphics 3D - Medium: 914.2
    Graphics 3D - Complex: 10.2 <<--------------------------
    Graphics 3D - DirectX 10: 43.8
    Memory - Allocate Small Block: 3267.2
    Memory - Read Cached: 1105.8
    Memory - Read Uncached: 1091.3
    Memory - Write: 1182.8
    Memory - Large RAM: 2872.9
    Disk - Sequential Read: 70.8
    Disk - Sequential Write: 27.2
    Disk - Random Seek + RW: 3.3
    CPU Mark: 3382.0
    2D Graphics Mark: 212.9
    Memory Mark: 1119.6
    Disk Mark: 366.3
    3D Graphics Mark: 1984.7
    PassMark Rating: 1065.1
  • Mangled
    • Jun 2012
    Processor is AMD Athlon II X4 630 2.8ghz
    8gb Ram
    using HDMI connection to acer 23'' monitor
      If you run the test a few times are the results consistent?
      • Mangled
        • Jun 2012
        Actually no, I just did however and got a 40, thats alot better than 10. I just have a feeling when I play certain games I should have more FPS than I do. Gona try Evga Precision X to see if slightly overclocking would help.
          The low result for that one test probably means there was some other task running in the background when that test was executed.
