best value for performance processor help!
  • nightyard
    • Jul 2012
    hi,
    Looking to build a build of a small budget, the cpu that I think seems the best value is the AMD 651k (cant find any benchmarks for this particular one)
    this one
    http://www.ebuyer.com/343930-amd-athlon-ii-x4-651-ad651kwngxbox-ad651kwngxbox
    is there a better value for money CPU?? I can spend more but don't want to spend silly money.
    Unless you are overclocking the performance should be near identical to the AMD Athlon II X4 651.
    http://www.cpubenchmark.net/cpu_look...+651+Quad-Core
    That is to say, it is a mid range CPU.
    You can find a chart of the best value for money CPUs here,
    http://www.cpubenchmark.net/cpu_value_available.html
    The 651 is near the top at the moment.
