Radeon HD6570 strange result
  • Fedewiico
    • Nov 2012
    It seems that if you use the card itself it scores 784, but if you use it in dual graphics mode with an AMD APU trinity built-in 7560D, toghether they score 730
    Should it be better to disable the 7560D and use only the card?
    We haven't tested this particular scenario ourselves, but it wouldn't surprise me if this was the case. Use the external card when you want performance and the internal card for low power operations.
