Replacement for ASUS M4A78 Pro Motherboard
  • mtnlvn
    • May 2018
    I seem to have shorted a USB cable and fried something on the motherboard. System will power-on, but never get to the BIOS or display anything on the screen. Thinking I need a new motherboard.
    Primary use is some digital image post processing and video/music streaming within my home. I would like to retain my storage and leverage my exisiting memory.
    Can anyone recommend a replacement motherboard that will fit the mounting holes and has the two "small" PCI Express x1 slots?
    This is an old motherboard. It used DDR2 RAM. I don't think you can buy a new motherboard that uses DDR2 anymore.
    If you have the budget get a complete new machine. If you don't have a look around on Ebay for a 2nd hand MB. Unless you have some unusual case, most motherboards will have compatible mounting holes.,
