Geforce GTX 1060 3GB low benchmarks
  • dolbinau
    • Oct 2018
    Hi all,
    My GTX 1060 3GB is getting some pretty low benchmarks
    4299 overall
    47 for DX9
    100 for DX10
    179 for DX11
    20 for DX12 (but don't have 4k monitor)
    3657 for GPU compute.
    Any ideas?
    What CPU is in the machine?
    See this post to start with
    • dolbinau
      • Oct 2018
      I've investigated further, the issue is that my PCI-E 16X is only running at 1X. I can get a band-aid workaround by putting it into the PCI-E 8X port...not sure how to revive the 16X though .
        Glad you got to the bottom of it.
        Best solution depend on the motherboard, the available slots and what other PCIe cards you are using. (and also depends on why x16 doesn't work).
