Hard Drive question
  • iash
    • Feb 2014
    Hard Drive question
    what's the difference between 500 GB 5400 rpm SATA vs 750 GB 5400 RPM hard drive?
    Exactly 250GB.
    • frazmi
      • Feb 2014
      What if "Drive 2" is not SATA?
      Exactly 250GB.
      That's assuming the 750GB drive is also SATA... If it's an external USB drive or possibly an old-style IDE internal drive, the capacity difference would be exactly as David said, but the transfer rates would be different (SATA is likely to be the fastest).
