2070 super score seems low. Help??
  • Frankyy
    • May 2020
    Hi all, I'm fairly new to this scene. I have recently built a new system and am testing out some benchmarks but I'm concerned my GPU score is really low for 3d.
    I'm running:
    ASRock phantom gaming 4 x570
    Ryzen 7 2700x
    32GB Corsair Vengeance RGB 3200mHz
    and the most recent addition is my Asus ROG 2070 super
    When I run the performance test my 3d score comes back as 12732, which seems really low in comparison to other scores I see for this card. I've also tried running MSI afterburner with OC scanner and it boosts it 39mHz but then I can't do the 3d test as it just freezes on the DX9 test.
    Please help, I really don't know if this is normal, if there's a setting I need to change or what. (Sorry if I sound like a bit of an idiot but it's been years since the last PC I built and I haven't kept up to date at all)
    That result does seem very low for the card and it sounds like the results are down for all the 3D tests (is that correct?).
    See this page to start with - Causes and Solutions for a slow PC.
