Will she do?
  • Sanvich
    • May 2014
    Will she do?
    Wishlist Link: http://amzn.com/w/N6732K42WCMW
    ASUS E818AAT (DVD Drive)
    Logisys LT400RD (Case Fan 80mm x2)
    Logisys CS308RD (Case)
    Western Digital WD15EARS (Hard Drive)
    MSI Computer Corp. A55M-E35 (Motherboard)
    G.Skill F3-10666CL9D-8GBRL (RAM)
    Sapphire 100315L (Video Card)
    AMD AD5300OKHJBOX (CPU)
    1) Will this computer build be suffice to run "World of Warcraft" on High Settings smoothly?
    2) Will the "480W Power Supply" that comes with the Logisys Case be suffice to power this?
    I am on a budget, if you have suggestions? Please be mindful of that. I understand spending more will be better in the long run but to be honest? More doesn't and probably will never exist.
    "Keep your feet on the ground." They said. :P
    World of Warcraft will be the computer's sole duty. Nothing more; this is just a second PC for my girlfriend's addiction. :P
    (And yes, I know the HD is horrid. Don't hurt me.)
    • 11112
    WoW is an old game now.
    Almost any new hardware will run it OK.
    Having said that your parts are pretty low end.
    Can you install the O/S from a USB drive, then you might not need the DVD drive.
    As the CPU, PSU, Case & GPU all already have fans, you might not need the extra case fan.
    PSU should just be enough. A quality 500W unit would (of course) be better.
    • Sanvich
      • May 2014
      So 480W on a power supply is a no go?
