My AMD watercooled system needs a tune up. Any suggestions guys?
  • HERMS-SOUTHAFRICA
    • Oct 2013
    This Computer
    PerformanceTest Information:
    PerformanceTest Version: 8.0 (1022) WIN64
    PassMark Rating: 2751
    System Information:
    System Name: HERMS
    Model:
    Operating System: Windows 8 build 9200 (64-bit)
    Motherboard Manufacturer: MSI
    Motherboard Model: 890FXA-GD70 (MS-7640)
    Motherboard Version: 1.0
    BIOS Manufacturer: American Megatrends Inc.
    BIOS Version: MSI - 20121031
    BIOS Release Date: 2012/10/31
    CPU Information:
    Manufacturer: AuthenticAMD
    Type: AMD Phenom II X6 1055T
    Codename: Thuban
    CPUID: Family 10, Model A, Stepping 0, Revision PH-E0
    Socket: AM3
    Lithography: 45nm
    Number of CPU's: 1
    Cores per CPU: 6
    Logicals per Core: 1
    Clock Frequencies:
    Measured Speed: 3501.4 MHz [Turbo: 3501.2 MHz]
    Multiplier: 14.0X
    Bus Speed: 250.1 MHz
    Front Side Bus Speed: (N/A)
    Timing Error Ratio: 1.000
    Cache per CPU package:
    L1 Instruction Cache: 6 x 64 KB
    L1 Data Cache: 6 x 64 KB
    L2 Cache Size: 6 x 512 KB
    L3 Cache: 6 MB
    Memory Information:
    Total Physical Memory: 16383MB
    Available Physical Memory: 14631MB
    Memory Devices:
    Slot 1: 4GB DDR3 SDRAM PC3-10600
    Kingston 9905471-011.A00LF, wk/yr: 36/2011
    1.5V, Clk: 666.7MHz, Timings 9-9-9-24 (@ Max. freq.)
    Slot 2: 4GB DDR3 SDRAM PC3-10600
    Slot 3: 4GB DDR3 SDRAM PC3-10600
    Kingston 9905471-015.A00LF, serial#: 370563032, wk/yr: 24/2012
    Slot 4: 4GB DDR3 SDRAM PC3-10600
    Kingston 9905471-015.A00LF, serial#: 387336408, wk/yr: 24/2012
    Virtual Memory: C:\pagefile.sys (2304MB)
    Drive Information:
    Physical Drive 1: Corsair Force 3 SSD ATA Device
    Drive Size: 111GB
    Partitions: C:
    Interface Type: ATA
    Bytes per Sector: 512
    RPM: Solid State
    Physical Drive 2: ST3500418AS ATA Device
    Drive Size: 465GB
    Partitions: F:
    Interface Type: ATA
    RPM: 7200
    Physical Drive 3: WDC WD20EARX-00PASB0 ATA Device
    Drive Size: 1863GB
    Partitions: D:
    Interface Type: ATA
    RPM: Unknown
    Optical Drive 1: DTSOFT Virtual CdRom Device
    Optical Drive 2: TSSTcorp CDDVDW SH-222AB ATA Device
    Volume Information:
    Volume 1: C: [Local drive]
    File System: NTFS
    Drive Cluster Size: 4KB
    Volume Size (Free space): 111.8GB (61.1GB)
    Volume 2: D: [Local drive]
    File System: NTFS
    Volume Size (Free space): 1863.0GB (179.8GB)
    Volume 3: E: [Optical drive]
    File System:
    Drive Cluster Size:
    Volume 4: F: [Local drive]
    File System: NTFS
    Volume Size (Free space): 465.8GB (38.9GB)
    Volume 5: G: [Optical drive]
    File System:
    Drive Cluster Size:
    Video Adapters:
    Description: AMD Radeon HD 7850
    Chip Type: AMD Radeon Graphics Processor (0x6819)
    DAC Type: Internal DAC(400MHz)
    Memory: 2048MB
    Video BIOS: 113-C40304-170
    Driver Provider: Advanced Micro Devices, Inc.
    Driver Version: 14.100.0.0
    Driver Date: 4-17-2014
    Monitor 1: 1360x768x32 60Hz (Primary monitor)
    Temperatures:
    Description: CPU 0
    Temperature: 23.00C
    Description: HDD 0 (ST3500418AS ATA Device)
    Temperature: 31.00C
    Description: HDD 1 (WDC WD20EARX-00PASB0 ATA Device)
    Temperature: 29.00C
    Description: HDD 2 (Corsair Force 3 SSD ATA Device)
    Temperature: 30.00C
    Description: GPU 0 (AMD Radeon HD 7800 Series)
    Temperature: 41.00C
    I don't think you are going to squeeze too much more out of this 4 year old CPU.
    I would save my money and replace the entire system later this year.
    Get a X99 motherboard, Haswell-E CPU, DDR4 RAM, M.2 SSD (make sure it is a NVMe one however).
    • HERMS-SOUTHAFRICA
      • Oct 2013
      AMD system
      Thanks David.
      Will most definitley follow your advice. Will most definitely follow your advice.
