Corsair CML8GX3M2A1866C9 4GB Low results
  • arcanux
    • Sep 2014
    Hi
    I did recently a performance test on my components to check if they perform as they should...
    CPU and GPU gave me standard results in line with normal values but my memory gave me numbers way below the normal ones
    Here is my Rig:
    MB : Asus M5a78L-M/usb3 (most recent bios 1801)
    CPU : AMD FX 6100
    GPU Asus Radeon HD7770 1GB DDR5
    RAM : 2x Corsair CML8GX3M2A1866C9 4GB (Timings on bios: 9 10 9 27)
    The values for the memory test:
    Memory - Latency
    This Computer 61.4
    Memory - Read Uncached
    This Computer 5689
    Memory - Write
    This Computer 4800
    Half the performance i normally would expect. Can anyone shed some light on what the problem should be?
    Tks on advance
    The current generation of AMD CPUs do significantly worse than that the current Intel CPUs in the memory test. Your memory results are in line with the others if you look only at the AMD Memory Charts.
    Latency with AMD CPUs
    Read Uncached with AMD CPUs
    Memory Write with AMD CPUs
    • arcanux
      • Sep 2014
      Ok, tks for the info!
