Radeon RX 5700 XT scoring significantly lower than "average"
  • Illuminatus
    • Dec 2020
    Hi guys,
    According to this page, Radeon RX 5700 XT scores 16729 on average: https://www.videocardbenchmark.net/g...700+XT&id=4111
    However, even with overclocking, the highest I can get mine to benchmark is 11500. Does anyone have any ideas for this 5000 point discrepancy?
    Here are my PC specs:
    MOBO: ASRock B450M Pro4
    CPU: AMD Ryzen 5 3600 6-Core Processor, 3593 Mhz, 6 Core(s), 12 Logical Processor(s)
    GPU: PowerColor AMD Radeon RX 5700 XT Red Devil 8GB GDDR
    RAM: Patriot Viper Steel 16GB (2x 8GB) 3200MHz DDR4
    HDD: SATA SSD
    PSU: Antec NeoECO Gold ZEN 700W 80+ Gold PSU
    OS: Microsoft Windows 10 Pro
    Thanks!
    See this post to start with
    • Illuminatus
      • Dec 2020
      Yeah, I went through that checklist a week ago and actioned all those criteria. My PC is not slow; I am just not hitting the reported "average" for this video card (which I scarcely believe, since I've dropped quite a lot of cash on this PC).
      I am just clicking "3D MARK > RUN" in PerformanceTest to get the 11500 rating.
        Can you post the individual CPU & 3D results from the machine when at stock clock speed.
        • Illuminatus
          • Dec 2020
          CPU Mark
          This Computer 15302
          Integer Math
          This Computer 41347
          Floating Point Math
          This Computer 24209
          Prime Numbers
          This Computer 96.2
          Extended Instructions (SSE)
          This Computer 12532
          Compression
          This Computer 189101
          Encryption
          This Computer 11928
          Physics
          This Computer 1119
          Sorting
          This Computer 20699
          CPU Single Threaded
          This Computer 2134
          Cross-platform Mark
          This Computer 28358
          3D Graphics Mark
          This Computer 11340
          DirectX 9
          This Computer 88.6
          DirectX 10
          This Computer 149.4
          DirectX 11
          This Computer 300.8
          DirectX 12
          This Computer 47.5
          GPU Compute
          This Computer 6650
            CPU results are also a bit low (10% to 20% down). So I don't think it is a problem only with the video card.
            Here is the distribution graph for CPUMark benchmark result for the Ryzen 5 3600 CPU. You are just off the bottom of the graph (i.e. in the lowest 5%)
            So something is slightly wrong.
            All the common issues really are covered in that post I linked to above however. Temperatures, BIOS settings, poor cooling, too much bloatware, etc..
            • Illuminatus
              • Dec 2020
              You won't cunting well believe this. (Apologies for my foul language.)
              I had the Radeon in the wrong slot! The motherboard slots were labelled PCIE2 (which I assumed was the old PCIE 2.0 standard) and PCIE3 (which I assumed was the new PCIE 3.0 standard my card needs). Turned out ASRock just label things whatever they want. Always check the manual! Radeon needed to go in middle slot PCIE2 on this motherboard.
              The card is now benchmarking at 18673!
              I also changed Windows power plan to AMD Ryzen High Performance which has boosted CPU up to 18027.
              So my PC is now actually working properly for a change!
              Thanks. Although you didn't help directly, posting here somehow steered me to the right answer.
              Maybe you could add the points about checking GPU is in correct slot, and that power plan is set to high performance, to your idiots' guide?
                Wrong PCIe slot is already in the 'idiots' guide' to slow PCs.
                Here,
                https://forums.passmark.com/performa...3028#post23028
                Power plan settings are also in the guide. Here
                https://forums.passmark.com/performa...7566#post17566
                • Illuminatus
                  • Dec 2020
                  Oh, I didn't realize there were more posts further down. Okay, thanks.
