Could not detect PCIe loopback card
  • cesar085
    • May 2021
    I did a test with the burnintest 9.2 and I got the following error "could not detect PCIe loopback card". What should I do to solve the problem?
    • 337
    Have you purchased the PCIE test card?
    The PCIe loopback test only works with the PCIe test card.
    If so, do you have the device driver installed on that PC? Drivers here: https://www.passmark.com/products/pc...d/download.php
    Could you also try installing the card in a different PCIE slot?
    If the error persists, trying to run the test again in debug mode (Instructions here: https://www.passmark.com/support/bitdebug.php) and send the logs for us to have a look.
