Is my System Benchmark Correct?
  • zappedrepair
    • Jan 2015
    Hi thanks for the help in advance.
    I just put back together my old system, and was wondering if it running where it should be?
    My question is mostly about the Video. I have 2 560ti cards. but it seems like it is only using 1.
    Secondly is this system fast enough to give to my son for some gaming? I built it like 3 years ago. So I know it's not up to date.
    Lastly what would need to be replaced?
    Frank
    The i7-2600K was a good CPU. If you 5Ghz overclock is stable, then it should be fine.
    16GB of RAM is enough. SSD is OK.
    Yes, the 3D result is a little down on what I would expect for SLI. You might be able to play with the SLI setting in the device driver to get a better result. You have the latest drivers, right?
    See,
    http://www.passmark.com/forum/showth...ormanceTest-V8
    Should be OK overall. If you change anything I would suggest it should be the video card(s).
