Will USB loopback plugs work on USB 3.2 + ?
  • chomwitt
    • May 2019
    Hi.
    I wonder if Passmark's USB loopback plugs can work on newer versions of USB , like USB 3.2 (Gen1,Gen2, ,Gen 2.2) .
    The USB 3.0 Loopback Plug will work; however, the tester iteration of the loopback plug is only capable of testing up to USB 3.0 speeds (5Gbps). You can use an USB 3.1 cable to test a USB C port, but it will only test up to 5Gbps.
    • chomwitt
      • May 2019
      So the power/voltage/IO activity testing will work for all USB versions but the max limit of speed displayed is 5Gps ?
      What about USB3Test?
