Help - Low score with decent components?
  • cr!s
    • Apr 2022
    Hello guys,
    I just upgraded my video card but i don't understand why my performance is so low
    Results are here:
    https://www.passmark.com/baselines/V...d=154740414686
    I also have a Samsung G9 Odyssey monitor and a Corsair RM650 PSU
    Could my PSU be the issue or the monitor?
    If i play Warzone, i get 30 fps with 2560x1440 resolution (everything at high settings) with RTX on and also off is the same.
    I did a lean driver installation and followed a lot of guided out there but still the same..
    Any help is appreciated,
    Thank you
    See this list to start with. It covers the common problems
    https://www.passmark.com/support/per...erformance.php
    CPU, memory and disk results seem OK.
    The problem is largely limited to 2D (the image rendering subtest) and the 3D (DirectX 9 subtest).
    Definitely nothing to do with the PSU.
    My guess is that is it related to video card device driver install (or its settings).
