Low CPU Score on Dell T5500 with Xeon X5670 - HT & Multi core enabled
  • visualchemistry
    • Jul 2015
    Hello
    Thought I'd postin general - I am just curious as to the low CPU score of this unit compared to similar Xeon X5670 based systems - I have hyperthreading enabled and multi-core but I'm getting a low CPU score
    Any Ideas?
    My 1st post so please be gentle
    James
    General Information
    Version 8.0.1047
    434453
    Windows 7 Professional Edition Service Pack 1 build 7601 (64-bit)
    1st of July, 2015
    Benchmark Scores
    3,084
    5,036
    642
    4,533
    1,768
    2,705
    Hardware
    It seems your CPU is only reporting 3 cores instead of 6, which would account for why the score is so low, have you checked the core settings in msconfig?
    If you open msconfig, go to the boot -> advanced options and make sure the the number of processors option is unchecked (this may be limiting your CPU to 3 cores).
    It also doesn't hurt to check the power options in control panel to make sure the system it isn't set to a power saving instead of high performance mode.
