Intel 14600K / 14600KF physics score too low
  • mjaszke
    • May 2025
    I have just do Passmark tests on my private Intel 14600KF (no OC - stock) and my physics score is 3500 (i done it few times), not 2485 like in your tabels. It looks like in real it is much much higher and in my opinion it should be corrected (ot is only 500 pts lower than for 9800X3D what is worth to mention). Why it is so low in your database? What is the reason of the difference as high? Kindly regards.
    • 969
    The displayed physics results are averages from users' submissions. We have close to 1500 submissions for Intel Core i5-14600K and 2200 submissions for Intel Core i5-14600KF. With physics scores ranging from 550 to 4418.
    ​​​​​​​The Physics test is more dependent on RAM bandwidth than CPU clocks speeds. CPUs with better memory bandwidth will perform better in this test. Also take into account, poor choices with RAM (e.g. slow, cheap, single channel RAM) and possible thermal cooling issues may result in lower scores as well.
