Scripting able to provide misc info?
  • 2Biased
    • Jun 2007
    After playing around with the scripting capabilities I was wondering if there are some undocumented features.
    When running from a USB flash drive it would be nice to store the results with different names. For example, is it possible to use standard DOS batch commands as part of a PTS script file? This could be used to store the results of tests at least under different dates or so.
    Thanks in advance - and for the program in general
    At the moment there is not an option to store results with dymanic file names, such as the date. We have added this to our candidate feature list for a future version of PerformanceTest (along wth expanding environment varables in a results file name).
    In the meantime, maybe you could try to use the EXECUTE command to run an external program to rename the file.
    Ian
