Cpu Problem - Help.
  • StarChild
    • Sep 2007
    Cpu Problem - Help.
    Hey guys, im not sure if this is the right section to ask about this, but I see stuff about cpu's and what not. Was wondering if you guys can help me in a little problem I have. My cpu is heating up to 50-60 Celsius - 131-150 Farenheit and restarting it self every time like every 1-2 hours that its up. Very simple to tell its because its overheating and safety feature is saving it from melting lol. I have never had to do this before, but I believe I put to much thermal glue on it so...How do I actually, when taking out the heatsink..remove the previous glue put on? What do I use to take it off and clean it up? I would appreciate everyones suggesting being that Im doing this for the first time.
    Thank you all,
    Oren
    Wiping it off with a cloth should be fine.
