Okay or not ? Core 2 Duo E6320 O/S - 935 PassMark Rating
  • anexX
    • Sep 2007
    Okay, Performance Test 6.1 Score: 935.2 Points.
    System:
    Motherboard: Asus P5K-SE
    RAM: 2 GB OCZ Gold DDR2 800 Dualchannel-Mode on 5-5-5-15 timings.
    CPU: Intel Core 2 Duo E6320 originally 1,86 ghz oc`ed to 3,15 ghz per core.
    Graphicscard: Leadtek Geforce 7800 GTX 256MB PCI-E
    Now as i have absolutely no plan about ...is that score good, bad, worse, evil or normal at all ?
    When looking at the Results-Table, all bars are quite high up, except the Read CD bar, that one is at start and shows 0,25 MB/Sec only..is that normal ?..if not, what could be the problem ? ...its a samsung sata dvd-drive.
    Thank for infos.
    Greetz, anexX
  • anexX
    • Sep 2007
    Ah, just got the idea is it maybe because i had no cd in drive ?
    Greetz, anexX
      You must of had some CD in the drive to get a result of 0.25MB/sec. To get the highest result use a CD (or DVD) with a small number of large files on it.
      The length of the bars is relative (so a long bar doesn't necessarily mean a good result). You need to compare you machine to others to know if the result is good or bad.
      But a PassMark Rating of 935 is a good result.
