Please Help! Pentium 4 @ 3.4gHz with rating of 309
  • bcotton
    • Oct 2007
    I just install a:
    Pentium 4 @ 3.4gHz
    800MHz FSB
    DDR2 2GB PC800
    I have seen others with way higher ratings but not a lot more than what I have installed. I am running my video off of the onboard video card (a better video card is on its way). I don't understand why I have such a low rating of 309. Also why is it that my cache size is not showing up on the test, I belive that it is 2MB. One other problem, I also have "Check It Diagnostics" and everytime that I run a memory test it fails, WHY!? If anyone has time to help out that would be cool.
    Thanks,
    Brent
    Benchmark Results
    Test NameThis ComputerCPU - Integer Math314.71CPU - Floating Point Math331.99CPU - MMX313.31CPU - SSE/3DNow!195.85CPU - Compression1972.41CPU - Encryption12.40CPU - Image Rotation227.76CPU - String Sorting1020.72Graphics 2D - Lines51.98Graphics 2D - Rectangles42.47Graphics 2D - Shapes17.62Graphics 2D - Fonts and Text121.79Graphics 2D - GUI156.03Graphics 3D - Simple189.84Graphics 3D - Medium218.95Graphics 3D - Complex73.92Memory - Allocate Small Block1233.01Memory - Read Cached1586.34Memory - Read Uncached1481.66Memory - Write675.57Disk - Sequential Read37.33Disk - Sequential Write32.98Disk - Random Seek + RW2.31CD - Read1.39CPU Mark543.872D Graphics Mark83.50Memory Mark485.22Disk Mark191.73CD Mark69.613D Graphics Mark160.90PassMark Rating309.79
    System information - This Computer
    CPU Manufacturer:GenuineIntel
    Number of CPU: 1
    CPU Type: Intel(R) Pentium(R) 4 CPU 3.40GHz
    CPU Speed: 3391.6 MHz
    Cache size: 0KB
    O/S: Windows XP
    Total RAM:2079502336 Bytes
    Available RAM:1666957312 Bytes
    Video settings: 1280x1024x32
    Video driver
    DESCRIPTION:
    VIA/S3G UniChrome Pro IGP
    MANUFACTURER:
    BIOS:
    98.A0.00.04
    DATE:
    03/14/06
    Drive Letter: C
    Total Disk Space: 111.8 GBytes
    Cluster Size: 4 KBytes
    File system:NTFS
    PassMark PerformanceTest V5.0 (http://www.passmark.com/)
    Results generated on: Monday, October 15, 2007
    Check It Diagnostics is not our product, so we can't help you with that.
    V5 of PerformanceTest is now pretty old. You should upgrade to V6.1. This should fix the cache display issue.
    You also can't directly compare V5 and V6 results. Which is probably what you are doing.
    • rogerk
      • Nov 2007
      Hi I dont think your score is bad look at the chart link below
      http://www.cpubenchmark.net/common_cpus.html
      P4 3.4 shows CPU Mark 526 yours is CPU Mark 543.87
      I think the final score (passmark rating) is confusing it is for all the components of your computer not just the CPU
      Roger
