Give Me Advice About My Laptop
  • gsvijaynjoy
    • Dec 2007
    I Am Using A Dell Xps M1330 Laptop. My Configration Is
    Intel Core 2 Duo T7500@2.2ghz
    2 Gb Ram
    Nvidea Geforce 8400m Gs
    160 Gb Sata Hard Drive
    Is 631.4 A Good Score For My Laptop?
    THIS SCORE IS NOT CONSTANT,WHEN I PERFORM THE TEST FOR THE FIRST TIME THE SCORE IS 604.5 WHEN I DO IT IMMEDIATELY AGAIN THE
    SCORE JUMPS TO 631.4,,WHY DOES THIS HAPPEN??
    It is normal the the score can vary by a few percentage points from one un to the next. Caching, disk fragmentation, background tasks, available RAM, etc.. can all change from one run to the next.
    You can compare you machine to other machines using the baseline results. A few are supplied with the eval software, and the rest of the baselines are available for download after the software is purchased.
    If you are just interested in the CPU performance, you can also compare your results CPU results to the CPU Benchmark Charts.
    • bana1988
      • Dec 2007
      this could be because you have more available memory the second time around or simply because there is less stress on you rcomputer the second time testing
