Running from CD
  • KawreS
    • Jan 2008
    Running from CD
    Is it possible to run PerformancTest from CD on multiple computers or do you have to install it on each computer you want to run it on? Right now, I am interested in PerformanceTest, but am also going to be possibly looking at BurnIn and would like to know the same about it. If it is possible, how do you go about doing it? I did a quick search on the forums, but couldn't find it.
    Thanks.
    You need to create a key.dat file as detailed in the FAQ.
    • KawreS
      • Jan 2008
      Thank you - I don't know how I missed that considering I remember reading the item right underneath it in the FAQ about how often the baselines are updated....
