Acceptable Frame Rate???
  • Anonymous
    • 286
    Hi all
    I'm getting a frame rate of 613FPS when I run the simple 3d graphics test. (20 objects, 1 texture, 20 sec.) I have a P4 512mb ram and a ATI Radeon 9000 with 128MB
    The trouble is I cant find anything to compare the frame rate to.
    Is 613 great, fair or poor under these conditions.
    Appreciate any and all assistance.
    Thanks in advance!
  • Robbie
    • 286
    amm..
    i have a (poor) asus Nvidia GII 64mb-sdram
    123 fps
    if it helps ...
    • Senior Member
      • 286
      oh ... and is it Ver 5 ?
      • Senior Member
        • 286
        I'm using Ver 4
        Barrie
        • Senior Member
          • 286
          Try downloading v5
          then see if it makes any changes
            The "Simple" test is part of the standard test suite in V5 and you can compare your result to the built in baselines or purchase the software and compare your result to even more machines.
            See.
            http://www.passmark.com/baselines/
            643 is a pretty good result, but fairly typical of new machines with good graphics cards.
            My development machine (P4 2.8Ghz, Radeon 7500 video, Dual LCD, 32bit color, DirectX9, Windows XP) gets 560 on the simple test in version 5.
            passMark
