Score To Low?
  • dominationXVO
    • Mar 2008
    Score To Low?
    I just bought this comp, it's a dell xps 420 4gb 800 mhz ram, 500gb hard drive, gforce 8800 gt, core 2 e6850 proc @ 3 ghz. My score is approx 900; this seems kinda low, is it correct? oh yeah, the CPU rating alone is only 477, i though it was supposed to be much higher.
    Yes the CPU mark score should be higher.
    See the post on common performance problems.
    In particular check the number of processes in the Edit / Preferences window
    • Dave987654321
      • Mar 2008
      I don't have a clue what's going on. My score is only 189.7!!
      Specs: Intel Core 2 Duo CPU E8400 3Ghz - 239.6
      Geforce 8600GT 512MB - 2D 47.1 3D 131.3
      2x 2MB Corsair 800Mhz - 90.1
      2 x 320Gb raid 0 - 351.2
      CD mark: 180.4
      Running Vista Home premium 64 bit
      It's brand new nothing apart from internet and Norton has been installed by me????
        It would help if you posted all the results, along with the version of PerformanceTest you are using.
