Can't read old baseline files with PT 6.1 build 1013
  • wonderwrench
    • Oct 2007
    • 264
    Build 1013 is not compatible with baseline files from version 4 of PT.
    Any version 4 baselines files that are in the install directory cause errors when PT is started. Error given, Read error, reading file filename.pt The file may be corrupt or you may have selected the wrong file. This error is given for every version 4 .pt file in the programs directory.
    This problem is new to PT 6.1 build 1013. No previous versions had this problem. .pt files made by PT versions 2, 3.3, 3.4, 3.5, 5.0 and 6.1 work fine.
    XP pro sp2 32 bit, PT 6.1 build 1013 x86. Previous version of PT uninstalled prior to installing build 1013. See sig for more system info.
    Bill
  • wonderwrench
    • Oct 2007
    • 264
    Same problem with build 1014.
      We'll have a look at the problem. But we might not get back to you until next week as the person responsible is away on leave this week this week.
      You can also download the old V4 software here if need be.
      • wonderwrench
        • Oct 2007
        • 264
        Ok, thanks. It's not a big deal. I have saved results from all system builds and since PT has had the ability to scale the results of previous versions its kind of cool to compare performance over the years.
          We have corrected this in PerformanceTest V6.1.1016 available from:
          http://www.passmark.com/download/pt_download.htm
          Sorry for the inconvenience.
          Ian
