Is there a place to look at scores?
  • FieroClint
    • May 2008
    Would like to see what other pc's are getting. Thanks
    You can compare your result to others by downloading some the 11,000+ baseline files that we keep in the baseline database (you need to purchase the software before you can use the files however). There are also a few example baseline files included with the PerformanceTest software (from the baseline menu).
    You can also compare just your CPU's performace by looking at the CPU charts.
    • FieroClint
      • May 2008
      Thanks, I'll buy it tonight
