My Radeon 9600pro results seems bad:(
  • Anonymous
    • 286
    I have radeon 9600pro, but its results are very low, both on 2d and 3d tests. I compare the results with others from the baseline who have the same one. My resusults are 2 or 3 time worse than the results of the others.
    What might be the problem? I already pre-intalled the triver and tried different versions. It did not help.
    If you have any idea what might cause my problem, please let mre know.
    There are other factors that can cause a speed difference. Including,
    - Video resolution
    - Colour depth (16bit or 32bit)
    - DirectX version
    - Video card device driver settings
    - If you have turned down video hardware acceleration
    - Overclocking
    - Your CPU speed
    - Your motherboard type, in particular the AGP slot speed
    - If you are running dual monitors (this has been seen to reduce performance on some cards)
    - For the 2D test, the setting of the visual effects options in the Windows control panel.
    - Any active background tasks you have running
    - Using the wrong device driver
    PassMark
