Anyone care to share some values for their 1333 or 1600mhz memory..
I have an asus p5e3 deluxe board with a q9650 3.0ghz cpu..
With auto settings i got a value of 1111 or so for 1333.. (for my old ddr2 in a different asus at 1066 i was getting around 88
I switched to "auto" 1600 and was getting only about 1258 or so..
Also..
I have ocz3g16004gk 2GB modules x 4 (8-8-8-26 and 1.8v), i had
trouble
getting most 1600mhz options to work.
The completely auto mode seemed to work, giving me a passmark memory
rating of 1228.. however, vista x64 was unstable, freezing at will,
mostly during file transfers.
Then i tried setting ai overclocking to manual and 1600 for dram and
AUTO for timings..
Odd thing is the bios reports 667mhz, but passmark ratings seem to
indicate 1600mhz ram with similar benchmarks..
The cpu reads 3.61ghz, whereas it should be 3.0ghz q9650 fsb 1333,
cpuz shows fsb at 1600..
Dram frequency says 400.4mhz (is this essentially 1600mhz then? ie:
400 x 4 cores)?
FSB:dram says 1:1, cas latency is 6, ras to cas delay is 7, ras
precharge 7, cycle time of 20, command rate 2T
In the SPD field the max bandwidth for slot#1 says 667mhz (perhaps
why
the bios says 667 on post, and pc3-10700F)?
I'm not clear on if i've done the right thing here or not.. or why
these bios postings are like this..
Also..
trouble
AUTO for timings..
400 x 4 cores)?
why
