Scripting and Baselines
  • nick77vet
    • Dec 2008
    In a script, is it possible to import a baseline into the results after the tests complete?
    I am not really sure what you are trying to do. Can you give a specific example.
    • nick77vet
      • Dec 2008
      Using a script, I would like to run a benchmark and then output that test's results with a baseline included.
        using the command line you can run PerformanceTest to generate benchmark results in HTML, text or CSV format. You can also do a similar task using the scripting options.
        See the PerformanceTest help file for details about command line options and scripting.
        At the moment there is no option to output a .pt baseline file (just HTML, text or CSV format).
