Extremely low mark for 3D – 1.8 (total)
  • avramm
    • Mar 2009
    I have an ABIT AV8 MB, AMD 3000+ processor, 2GB 400 Mem, and Gforce FX5200 video card.
    Most marks seem ok except for this one here are the performance marks:
    CPU 487
    2D 298
    3D 1.8
    Mem 344
    Disk 370
    CD 406
    Total Passmark 33.3
    Can anyone help me understand what makes my 3D so bad ?
  • wonderwrench
    • Oct 2007
    • 264
    Using XP sp3? What video driver are you using? If its the windows default driver this could cause low 3d performance. Please give complete system spec's.
    • avramm
      • Mar 2009
      Video Driver
      Thanks for the quick response,
      I am using the Nvidia driver, dated 22-10-2006
      Version: 6.14.10.9371
        Try updating the drivers to start with. They release new drivers every 2nd week. So anything from 2006 is now very old.
        • avramm
          • Mar 2009
          I downloaded new driver from 2008 and got the same results (even lawer number). can this be due to HW problem? Everything else seems good.
            What are the individual scores from the 3D tests (in frames / sec). Do you use any other 3D applications on this machine (e.g. newer games)?
            The 3D mark of the FX 5200 should be around 40. Which makes it a slow card, but not as slow as you are reporting.
            Also I just looked at the nVidia web site. For the GeForce FX series cards the latest driver is in fact from Oct 17th 2006, Version 95, if you are using Vista (i.e. they aren't really supporting Vista). But there is a much later release available for XP (Version 175.19).
            You didn't mention which O/S you are using, but also make sure it is up to date, especially with the latest DirectX.
            • avramm
              • Mar 2009
              Thanks again for the quick reply. I reverted back to the original driver from 2006:
              XP SP3 fully up to date with all windows update, DX 9.0c,
              3d test details are: 3d mark - 1.79 (On each result there is (N/A) mark )
              simple - 0.35
              Medium - 0.31
              complex - 0.46
              In addition, Attached is the DirectX diag of the main comp' and display where you can see all the relevant details of my machine:
              System Information
              Time of this report: 3/3/2009, 09:07:05
              Machine name: IMA
              Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
              Language: Hebrew (Regional Setting: Hebrew)
              System Manufacturer: VIAK8T
              System Model: AWRDACPI
              BIOS: Phoenix - AwardBIOS v6.00PG
              Processor: AMD Athlon(tm) 64 Processor 3000+, MMX, 3DNow, ~1.8GHz
              Memory: 2048MB RAM
              Page File: 707MB used, 3232MB available
              Windows Dir: C:\WINDOWS
              DirectX Version: DirectX 9.0c (4.09.0000.0904)
              DX Setup Parameters: Not found
              DxDiag Version: 5.03.2600.5512 32bit Unicode
              DxDiag Notes
              DirectX Files Tab: No problems found.
              Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
              Sound Tab 2: No problems found.
              Music Tab: No problems found.
              Input Tab: No problems found.
              Network Tab: No problems found.
              DirectX Debug Levels
              Direct3D: 0/4 (n/a)
              DirectDraw: 0/4 (retail)
              DirectInput: 0/5 (n/a)
              DirectMusic: 0/5 (n/a)
              DirectPlay: 0/9 (retail)
              DirectSound: 0/5 (retail)
              DirectShow: 0/6 (retail)
              Display Devices
              Card name: NVIDIA GeForce FX 5200
              Manufacturer: NVIDIA
              Chip type: GeForce FX 5200
              DAC type: Integrated RAMDAC
              Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_31031458&REV_A1
              Display Memory: 128.0 MB
              Current Mode: 1280 x 1024 (16 bit) (60Hz)
              Monitor: Monitor Max Res: 1600,1200
              Driver Name: nv4_disp.dll
              Driver Version: 6.14.0010.9371 (English)
              DDI Version: 9 (or higher)
              Driver Attributes: Final Retail
              Driver Date/Size: 10/22/2006 12:22:00, 4527488 bytes
              WHQL Logo'd: Yes
              WHQL Date Stamp: n/a
              VDD: n/a
              Mini VDD: nv4_mini.sys
              Mini VDD Date: 10/22/2006 12:22:00, 3994624 bytes
              Device Identifier: {D7B71E3E-4062-11CF-7353-091100C2CB35}
              Vendor ID: 0x10DE
              Device ID: 0x0322
              SubSys ID: 0x31031458
              Revision ID: 0x00A1
              Revision ID: 0x00A1
              Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
              Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
              {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
              {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
              {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
              {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
              {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
              {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
              {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
              {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
              {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
              {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
              {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
              Registry: OK
              DDraw Status: Enabled
              D3D Status: Enabled
              AGP Status: Enabled
              DDraw Test Result: Not run
              D3D7 Test Result: Not run
              D3D8 Test Result: Not run
              D3D9 Test Result: Not run
                If you are using XP then I would suggest using the latest drivers, version 175.19.
                You might then also want to look in the control panel for the card to ensure video hardware acceleration is on.
                Also try switching to 32bit color. Some older card can be funny with the color depth and only accelerate certain depths.
