Low CPU score Q6600
  • param
    • Jul 2009
    Low CPU score Q6600
    Hello. I have a non-oc'd q6600 with Max power =100% on the power saver, the latest bios and m/b drivers and this is what I get (4 cores in preferences):
    My problem is why are the CPU tests SO LOW?
    Other similar baselines give cpu - Integer math about 1100.
    Benchmark Results
    Test Name: This Computer CPU - Integer Math: 434.9 CPU - Floating Point Math: 1177.6 CPU - Find Prime Numbers: 762.9 CPU - Multimedia Instructions: 8.5 CPU - Compression: 5335.5 CPU - Encryption: 15.3 CPU - Physics: 220.9 CPU - String Sorting: 2881.4 Graphics 2D - Solid Vectors: 2.7 Graphics 2D - Transparent Vectors: 0.4 Graphics 2D - Complex Vectors: 132.8 Graphics 2D - Fonts and Text: 141.4 Graphics 2D - Windows Interface: 384.1 Graphics 2D - Image Filters: 361.0 2D Graphics - Image Rendering: 185.2 Graphics 3D - Simple: 288.9 Graphics 3D - Medium: 109.3 Graphics 3D - Complex: 27.8
    Memory - Allocate Small Block: 2360.4 Memory - Read Cached: 1867.2 Memory - Read Uncached: 1724.2 Memory - Write: 1780.4 Memory - Large RAM: 628.7 Disk - Sequential Read: 51.2 Disk - Sequential Write: 51.2 Disk - Random Seek + RW: 3.2 CPU Mark: 2834.8 2D Graphics Mark: 389.3 Memory Mark: 647.1 Disk Mark: 381.5 3D Graphics Mark: 275.5 PassMark Rating: 932.4
    System information: This Computer CPU Manufacturer: GenuineIntel Number of CPU: 1 Cores per CPU: 4 CPU Type: Intel Core2 Quad Q6600 @ 2.40GHz CPU Speed: 2114.7 MHz Cache size: 4096KB O/S: Windows XP (32-bit) Total RAM: 2047.1 MB. Available RAM: 1594.3 MB. Video settings: 1440x900x32 Video driver: DESCRIPTION: NVIDIA GeForce 8500 GT MANUFACTURER: NVIDIA BIOS: Version 60.86.26.00.09 DATE: 2-18-2009 Drive Letter: C Total Disk Space: 111.8 GBytes Cluster Size: 4.0 KBytes File system: NTFS
    They aren't.
    All are about normal, except the Interger maths. And maybe you were just unlucky and had some other task fireup at that moment.
    (e.g. your E-mail client decided to check for E-mails jus as you were running that test).
    Trying running just this test a few times to get a range of results.
