Why is C2D 6300 Integer Math so low
  • SuraPelle
    • Aug 2009
    After running multiple test with AV and Firewall off I still cannot get my CPU Integer Math any higher then 269.7. I have nothing going on in the background (no email etc.)
    Is there maybe a limitation with Intel C2D 6300? It is running at 3003 stable so I thought I should be able to get a little higher result. All the other CPU benchmarks seems "normal" but integer math sticks out.
    Any ideas? I'm concerned that I'm missing some setting in BIOS or some such.
    Thx!
    SuraPelle
    PassMark(TM) PerformanceTest 6.1 (http://www.passmark.com)
    Results generated on: Sunday, August 09, 2009
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 269.7
    CPU - Floating Point Math: 733.8
    CPU - Find Prime Numbers: 779.8
    CPU - SSE/3DNow!: 6249.6
    CPU - Compression: 6891.8
    CPU - Encryption: 42.0
    CPU - Image Rotation: 1398.1
    CPU - String Sorting: 3341.4
    Graphics 2D - Lines: 173.2
    Graphics 2D - Rectangles: 331.4
    Graphics 2D - Shapes: 17.0
    Graphics 2D - Fonts and Text: 385.5
    Graphics 2D - GUI: 410.1
    Graphics 3D - Simple: 2554.8
    Graphics 3D - Medium: 617.9
    Graphics 3D - Complex: 53.2
    Memory - Allocate Small Block: 2947.7
    Memory - Read Cached: 2309.1
    Memory - Read Uncached: 2136.1
    Memory - Write: 1914.3
    Memory - Large RAM: 670.7
    Disk - Sequential Read: 121.9
    Disk - Sequential Write: 102.2
    Disk - Random Seek + RW: 3.4
    CPU Mark: 1740.1
    2D Graphics Mark: 935.4
    Memory Mark: 737.7
    Disk Mark: 822.5
    3D Graphics Mark: 1032.4
    PassMark Rating: 1021.9
    Number of CPU: 1
    (2 Core(s)/CPU, 1 Logical(s)/Core)
    CPU Type: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
    CPU Speed: 3003.0 MHz
    Cache size: 2048KB
    O/S: Windows XP (WIN32)
    Total RAM: 2046.4 MB.
    Available RAM: 1537.5 MB.
    Video settings: 1680x1050x32
    Video driver:
    DESCRIPTION: NVIDIA GeForce 8800 GT
    MANUFACTURER: GeForce 8800 GT
    BIOS: Version 62.92.1F.00.02
    DATE: 12/05/07
    Drive Letter: C
    Total Disk Space: 39.1 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    My guess is that you are comparing results from different versions of PerformanceTest.
    You are using the old release, V6.
    You should also be careful comparing 32bit and 64bit results. The 64bit machines score a bit higher on the CPU tests.
    So you should upgrade to the newer V7 release.
    You can't really directly compare V6 and V7 results.
      See also this post about the Integer maths test and differences between 32bit and 64bit.
