Unexpected difference between 2cpus @ same system
  • Hardtoid
    • Nov 2009
    Hi to all! I own a e5300 dual core & a e4500 core2duo cpu. I benchmarked one after another placing them at the same PC. Perfomance test showed that the e5300 cpu, gives 50% less mark than the results of e4500. Actually, checking what e5300 marks should be like, my benchmark is 60% lower. I think that soimething is wrong here but I can't find out what.
    Thank you.
    You need to check out the indivdual scores to see which score was low, pulling down the overall result. e.g. was the it disks core, the memory benchmark, 3D, etc..
