Test from USB
  • scraw
    • Dec 2009
    Test from USB
    I ran the test on my laptop after I installed the program. Then I copied the program to a 64mb SD disk and ran it again thru my card reader. The results were about 10-20% less. Is this normal?
    On the first run you were probalby testing your main hard drive. Which is probalby quicker than the SD disk. You can select which drive to test from the Edit / preferences window.
