Dream machine test results -
  • lincoln069
    • May 2005
    Hello - I just purchased this machine from ABS, and could use some help analyzing the performance test results.-
    here are the spec's, the machine has 2 - PCI Express Geforce 6800 GT video cards :
    eneral Spec
    Brand ABS
    Series ULTIMATE
    Model M6 Pro
    Form Factor Aluminum Mid Tower Chassis W/ Transparent X Type Side Panel Window, Mirror Coating
    Colors Black
    Power Supply Antec TRUE550W EPS12V, +3.3V@32A;+5V@40A;-5V@0.5A;+12V@36A;-12V@1A;+5VSB@2A
    Operating System Windows XP Pro
    Orientations Allowed Vertical
    Motherboard
    Motherboard Name ASUS A8N-SLI Deluxe NF4 SLI
    CPU
    CPU Type Athlon 64
    CPU Speed 3500+(2.2GHz)
    L2 Cache Per CPU 512KB
    CPU Socket Type Socket 939
    Graphics
    GPU/VPU Type nVIDIA GeForce 6800GT
    Graphics Card 2 X of nVIDIA GeForce 6800 GT PCI-Express x 16/350MHz, 256MB GDDR3, Dual DVI/TV-Out
    Memory
    Memory Capacity 1GB
    Memory Spec Xtra-Low Latency 184-Pin 1GB(512MBx2),TWINX1024-3200XL, 2-2-2-5, 3.2GB/s
    Hard Drive
    HD Capacity 200G(SATA)
    HD RPM 7200rpm
    HD Spec 8MB Buffer Memory
    Optical Drive
    Optical Drive Type DVD±RW; DVD-ROM
    Optical Drive Spec 16X Dual Layer DVD+/-RW Layer Drive Black
    Supplemental Drive
    FDD 1.44 MB Floppy
    Audio
    Audio Chipset Realtek ALC850, 8-channel CODEC; Audio Sensing and Enumeration Technology
    Audio Channels 9 Channel
    Communications
    LAN Chipset Marvell 88E8001 GbE Gigabit Lan PCI Controller supporting 10/100/1000 BASE-T Ethernet; nForce4 built-in Gbit MAC with external Marvell PHY: NY ActiveArmor, NV Firewall, AI Net2;
    LAN Speed 10/100/1000Mbps
    Front Panel Ports
    Front USB 2
    Front IEEE1394 1
    Front Audio Ports 2
    Back Panel Ports
    COM 1
    LPT 1
    PS/2 2
    TV-Out 2
    Rear USB 4
    Rear IEEE1394 1
    RJ45 2 port
    Expansion
    External Bays 2x 3.5" external bays, 4 x 5.25" external bays
    Internal Bays 5x 3.5" internal bays (For Hard Drive),
    PCI Slots (Available/Total) 2 x PCI-Express X16 (SLI mode : x8 , x8 Default Single VGA mode : x16, x1),2x PCI-Express X1, 3x PCI
    Physical Spec
    Dimensions 17" H x 7.5" W x 18" D
    Weight Approximately 23 lbs
  • lincoln069
    • May 2005
    PASSMARK RATING-- 413.6 ;(
    Benchmark Results
    Test Name This Computer
    CPU - Integer Math 163.82
    CPU - Floating Point Math 321.22
    CPU - MMX 308.08
    CPU - SSE/3DNow! 108.68
    CPU - Compression 2015.00
    CPU - Encryption 9.86
    CPU - Image Rotation 141.21
    CPU - String Sorting 1171.91
    Graphics 2D - Lines 198.77
    Graphics 2D - Rectangles 52.51
    Graphics 2D - Shapes 1.73
    Graphics 2D - Fonts and Text 224.53
    Graphics 2D - GUI 390.44
    Graphics 3D - Simple 668.09
    Graphics 3D - Medium 1753.16
    Graphics 3D - Complex 720.21
    Memory - Allocate Small Block 1868.58
    Memory - Read Cached 749.97
    Memory - Read Uncached 719.23
    Memory - Write 758.37
    Disk - Sequential Read 50.66
    Disk - Sequential Write 49.55
    Disk - Random Seek + RW 8.20
    CD - Read 2.73
    CPU Mark 448.67
    2D Graphics Mark 181.75
    Memory Mark 399.37
    Disk Mark 286.19
    CD Mark 136.26
    3D Graphics Mark 1047.15
    PassMark Rating 413.63
    System information - This Computer
    CPU Manufacturer:AuthenticAMD
    Number of CPU: 1
    CPU Type: AMD Athlon(tm) 64 Processor 3500+
    CPU Speed: 2210.8 MHz
    Cache size: 512KB
    O/S: Windows XP (WIN32)
    Total RAM:1073197056 Bytes
    Available RAM:689348608 Bytes
    Video settings: 1280x1024x32
    Video driver
    DESCRIPTION:
    NVIDIA GeForce 6800 Series GPU
    MANUFACTURER:
    GeForce 6800 GT
    BIOS:
    Version 5.40.02.36.08
    DATE:
    01/25/05
    Drive Letter: C
    Total Disk Space: 186.3 GBytes
    Cluster Size: 4 KBytes
    File system:NTFS
    • greasekiss
      • Jun 2005
      wacko
      Those results seem low for what you spec'd out.
      Im on an ASUS P5WD2 Premium + Intel 3.4
      Im assuming you are using SLI?
      My 3D result in winxp32 is 1450ish and i have only one card.
      2D - @250
      ill retest it here once i reinstall 32bit os... and post all my results.
        I agree that it seems a bit low. Especially the 2D / 3D graphcis.
        You might want to have a look at this post about SLI,
        http://www.passmark.com/forum/viewtopic.php?t=270
        Then you might want to re-test with just 1 card installed.
