hd 5850 low 3d mark
  • thursdaysrgreat
    • Feb 2010
    hd 5850 low 3d mark
    PassMark(TM) PerformanceTest 7.0 Evaluation Version (http://www.passmark.com)
    Results generated on: Thursday, February 25, 2010
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 1665.8
    CPU - Floating Point Math: 2148.2
    CPU - Find Prime Numbers: 1076.8
    CPU - SSE: 15.7
    CPU - Compression: 4103.0
    CPU - Encryption: 16.5
    CPU - Physics: 324.5
    CPU - String Sorting: 3535.2
    Graphics 2D - Solid Vectors: 1.8
    Graphics 2D - Transparent Vectors: 0.6
    Graphics 2D - Complex Vectors: 59.4
    Graphics 2D - Fonts and Text: 104.1
    Graphics 2D - Windows Interface: 37.6
    Graphics 2D - Image Filters: 218.7
    2D Graphics - Image Rendering: 427.1
    Graphics 3D - Simple: 45.8
    Graphics 3D - Medium: 43.9
    Graphics 3D - Complex: 23.4
    Memory - Allocate Small Block: 4165.2
    Memory - Read Cached: 2149.8
    Memory - Read Uncached: 2064.6
    Memory - Write: 1259.7
    Memory - Large RAM: 1907.9
    Disk - Sequential Read: 57.8
    Disk - Sequential Write: 60.1
    Disk - Random Seek + RW: 2.3
    CD - Read: 3.5
    CPU Mark: 4900.0
    2D Graphics Mark: 223.5
    Memory Mark: 1054.8
    Disk Mark: 435.0
    CD Mark: 432.3
    3D Graphics Mark: 124.3
    PassMark Rating: 871.1
    Number of CPU: 1
    Cores per CPU: 4
    CPU Type: Intel Core i5 750 @ 2.67GHz
    CPU Speed: 2681.0 MHz
    Cache size: 256KB
    O/S: Windows XP Professional (64-bit)
    Total RAM: 4086.8 MB.
    Available RAM: 3138.0 MB.
    Video settings: 1024x768x32
    Video driver:
    DESCRIPTION: ATI Radeon HD 5850
    MANUFACTURER: ATI Technologies Inc.
    BIOS: 113-585AZNF-11
    DATE: 2-2-2010
    Drive Letter: C
    Total Disk Space: 232.9 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    I have latest display drivers, latest directx drivers for xp, I have made sure my card is accelerated I have shut of dual monitors. I tried various preferences and resolutions. An ATI radeon hd 5850 should be acheiving 2000+ 3d graphics mark . . . nuff said.
    Are you sure the frame rate is not being limited to the monitor refresh rate. Having both the 3D simple & 3D medium return almost the same result is a possible indication that there is a frame rate limit.
    Also XP 64bit is a very rare O/S. Based on the submissions we get, only 0.01% of machines are running XP 64bit. This means you run the risk of seeing problem nobody else sees and many manufacturers will not be doing any QA against this rare O/S.
    See also this old post
    • thursdaysrgreat
      • Feb 2010
      huh . . .
      Thanks for the quick response. I did check that the performance test was set to max refresh rate under preferences. Is there any other way to make sure the tests aren't limited to the refresh rate? Besides both of the monitors are set to 60 hz wouldn't the fps top out at 60 not 45. I know that the OS may be rare but do you really think it would choke the video card that much? Oh and thanks for the post, I did go through it before I posted this thread.
