my cpu is very slow plz advice
  • welliam
    • Apr 2010
    I run the CPU test and I found it very slow , here is the result and my pc config
    http://www9.zippyshare.com/v/1665851/file.html
    plz advice
    thanks
    In the linked HTML file you are comparing your normally clocked CPU to overclocked CPUs. So it is normal that your result is somewhat lower.
    • welliam
      • Apr 2010
      So is my speed normal ? but in your site it said the typical i7 860 score 5532 while mine score 4384.4, plz advice
      also how I know the normal clock results to choose ?
      thanks
        Maybe you are running the 32bit release of PerformanceTest on 64bit Windows? You should be running the 64bit release on 64bit Windows, it will score higher.
        • welliam
          • Apr 2010
          yes I scored now 5720, evga ftw is overclocked so it scored alot higher
          many thanks
