V7.0.Build 1015 Released
    PerformanceTest V7 build 1015 is now available.
    • Improved Advanced Memory Test. The tests were optimized to be tighter loops and should now return higher bandwidth results, making the steps from level 1 to level 2 cache to main RAM much more obvious.
    • Improved CPU Speed Detection on newer CPUs with turbo mode. Should provide a better indication of if a machine is overclocked than in previous builds.
    • Fixed corrupt icon graphics in system tab when the software was running on high DPI displays.
    • Fixed possible rare DX9 3D test crash in the "complex 3D test" were the test might crash after completion, during cleanup.
    • There was a suspected out of memory crash fixed. We suspect some people forced a high number of CPU test threads on low end systems. The number of test threads is now limited by available RAM. 50MB of RAM is now required per test thread, (after the initial 2 threads).
    • Added a function to collect mini-dumps in the case of crashes. This should make it easier to diagnose faults if people can send us the mini dumps.
    Full change release history is here.
    Download is here.
