What are the default settings for the basic disk test in Perfomance Test v. 7.0? There was an older thread with similar question, but when I input those values results are different under Advanced Test and Basic Test. Did the default values change, or my inputting something in wrong place?
Also, which test would you recommend to mimic typical harddisk usage in windows environment, i.e. browsing, running multiple instances of excels, words, dlls in background and other common applications? Synchronous / Asynchronous? Sequential/random? File size / block size?
Would be interesting to see which combination gives the highest speed. From some tests, cashed Win32 API instruction appears to be running almost twice the speed of uncashed for the block size tested.
Thanks,
Thanks,
. Do you see different values on the same drive. Even if these are partitions on the same physical drive testing different portions of the disk can yield different results.
