DirectX 10 result oddly low compared to other 3d results
  • rtpmid
    • Jan 2011
    Here is what I get:
    3d graphics mark - 355.3
    3d graphics simple - 580.3
    3d graphics medium - 114.2
    3d graphics complex - 31.8
    3d graphics directx 10 - 3.10
    The results seem fair except for DirectX 10, which seems unusually low. The directx came with with Vista and I updated from the Microsoft website. Passmark also updated directx.
    The rest of the computer tests good in it's class. Specs:
    Vista Home Premium 32 bit
    Pentium D 2.8 ghz (2 cores)
    2gb system ram
    Radeon hd 5450 1gb video
    The operating system has just been installed, and all updates installed also. I believe I have installed the latest video drivers as well.
    Any clues?
    Thanks,
    Bob
    This sounds about right, 3 frames per second.
    The Pentium D and the HD5450 are both underpowered.
    If you search our baseline database for Pentium class CPUs running a 5450 you'll see results between 2 and 4 fps for the DX10 test (which requires a lot of horsepower to get good results).
    • rtpmid
      • Jan 2011
      Thanks, I see.
      My card tested at about 189. The benchmark for the hd 5450 showed 324. Would that be related to the rest of the system, like cpu, mobo, and memory? I searched the website and couldn't find the database mentioned.
        You can access the database of results from within PerformanceTest.
        From the menu select Baseline / Install baseline from web.
        Then you can do some searches.
        Yes, a slow CPU will hurt the 3D results. MB and main RAM aren't so critical for the 3D test.
