Low score ?
  • darkhorse
    • Jan 2011
    • 7
    Low score ?
    Hi.
    I run a homebuilt computer here based on the ASUS P5Q Deluxe motherboard, and the Intel Core2 Duo E7300 @ 2.66Ghz processor.
    Graphics card is the NVIDIA GeForce 7300 LE with the latest driver 260.99.
    The system has 4G of RAM, and the OS is Windows 7 Ultimate 32bit.
    All drivers are the latest from ASUS.
    Having ran the Passmark Performance test, the score is just 559, and this is way too low ?
    What say ?
    /Erik
  • darkhorse
    • Jan 2011
    • 7
    Hi again.
    I don't know if this info has something to do with the low score ?
    No DirectX 10 capable video device found
    After the message, I click on 'OK', and the performance continues
    /Erik
      I suspect the warning is correct, the GeForce 7300 LE doesn't seem to support DirectX 10. It is a low end card with low performance.
      If you post your results we can probably tell you if it is just the video card that is slow.
      See also this FAQ
      • darkhorse
        • Jan 2011
        • 7
        All ok, and thanks for the reply.
        Do you mean I shall show the result here on the forum ?.
        If so, how do I copy/paste it ?
        Does the issue have influence also on the low score in Performance Test ?
        /Erik
        • darkhorse
          • Jan 2011
          • 7
          See also this FAQ
          Here I have results ready:
          PassMark(TM) PerformanceTest 7.0 (http://www.passmark.com)
          Results generated on: 16. januar 2011
          Benchmark Results
          Test Name: This Computer
          CPU - Integer Math: 203.8
          CPU - Floating Point Math: 829.6
          CPU - Find Prime Numbers: 559.3
          CPU - Multimedia Instructions: 4.0
          CPU - Compression: 2426.8
          CPU - Encryption: 6.7
          CPU - Physics: 73.4
          CPU - String Sorting: 985.8
          Graphics 2D - Solid Vectors: 2.2
          Graphics 2D - Transparent Vectors: 2.1
          Graphics 2D - Complex Vectors: 4630.1
          Graphics 2D - Fonts and Text: 64.0
          Graphics 2D - Windows Interface: 35.5
          Graphics 2D - Image Filters: 288.0
          2D Graphics - Image Rendering: 159.7
          Graphics 3D - Simple: 61.7
          Graphics 3D - Medium: 15.5
          Graphics 3D - Complex: 7.5
          Memory - Allocate Small Block: 1671.7
          Memory - Read Cached: 1266.7
          Memory - Read Uncached: 1449.9
          Memory - Write: 1279.2
          Memory - Large RAM: 879.4
          Disk - Sequential Read: 75.4
          Disk - Sequential Write: 70.6
          Disk - Random Seek + RW: 2.7
          CD - Read: 13.5
          CPU Mark: 1385.6
          2D Graphics Mark: 1970.1
          Memory Mark: 582.6
          Disk Mark: 537.8
          CD Mark: 1657.6
          3D Graphics Mark: 57.0
          PassMark Rating: 583.4
          Number of CPU: 1
          Cores per CPU: 2
          CPU Type: Intel Core2 Duo E7300 @ 2.66GHz
          CPU Speed: 2667.0 MHz
          Cache size: 3072KB
          O/S: Windows 7 (32-bit)
          Total RAM: 3327.0 MB.
          Available RAM: 1934.2 MB.
          Video settings: 1600x1024x32
          Video driver:
          DESCRIPTION: NVIDIA GeForce 7300 LE
          MANUFACTURER: NVIDIA
          BIOS: Version 5.72.22.78.0
          DATE: 10-16-2010
          Drive Letter: C
          Total Disk Space: 48.8 GBytes
          Cluster Size: 4.0 KBytes
          File system: NTFS
          /Erik
          • darkhorse
            • Jan 2011
            • 7
            Also here there is a result:
            http://www.urbakken.dk/BenchmarkResults.htm
              Your CPU score is also a bit down on the average.
              CPU Mark: 1385.6 vs and average of 1820 for the E7300
              Switching 64bit would help this and also give you access to another 680MB of RAM.
              • darkhorse
                • Jan 2011
                • 7
                Then what about what you siad about the NVIDIA card ?
                  CPU is slow (see above).
                  Video card is slow and doesn't support DX10 (see above).
                  Hard drive might be OK, but we don't know the model number, so hard to comment.
                  • darkhorse
                    • Jan 2011
                    • 7
                    Many thanks.
                    The Hard drive is a Western Digital WD1600AVVS-00L2B0 160GB
                      The drive is low capacity with a low amount of cache, designed to be 'green', reliable and used in AV applications, rather than fast. So r/w results of 70MB/sec are OK in this circumstance. Random seek time is low however (2.7MB/sec). It isn't a drive I would buy. Drive sounds OK for a media center, but capacity is too low, and performance is poor once you try and do 2 things at once (e.g record and playback at the same time).
