Running without installing
  • snick
    • Mar 2011
    I have installed the application on Win7 32-bit. I then ran File->Install PerformanceTest to USB drive and pointed the directory to C:\PerformanceTest. I then copied that folder to a server with Windows Server 2003 R2 32-bit under the same path (C:\PerformanceTest) and attempted to execute pt.exe.
    I was presented with:
    "Error during startup. A problem has occurred with your installation. you may need to uninstall and reinstall the software. Contact: www.passmark.com for support. Startup Error Number: 1."
    How do I get this to run on a server without installing it?
    TIA.
  • Michael (Passmark)
    • Apr 2007
    • 214
    An evaluation USB install must be run from a USB drive and not from a fixed hard drive. This limitation doesn't exist for registered copies.
    • snick
      • Mar 2011
      Excellent. I bought a copy and ran as suggested. Works without a hitch. Thanks!
