Low performance test score on HP Pavilion DV6-3013cl
  • priyantha
    • Mar 2011
    I ran performance test 64bit on my brand new HP Pavilion DV6-3013cl laptop and compaired with a base line form same model. Scores from my laptop are considerably lower than base line. Specially memory score is way below. I would like to get any feedback on what could cause this.
    Processor HP Pavilion dv6-3013 AMD Phenom II N930 Quad-Core 2.0 GHz
    OS W7 Home Premium 64bit
    RAM 4G
    Graphics ATI Radeon HD Mobile with 320mb memory.
    Scores for my laptop and base line as follows
    ComputerThis ComputerHP Pavilion dv6-3013 AMD Phenom II N930 Quad-Core 1995 Laptop BL369466CPU - Integer Math308.3392.1CPU - Floating Point Math1511.31966.3CPU - Find Prime Numbers417.5541CPU - SSE7.910.2CPU - Compression2092.92710.7CPU - Encryption9.512.1CPU - Physics133160.7CPU - String Sorting1701.31971.1Graphics 2D - Solid Vectors0.40.4Graphics 2D - Transparent Vectors0.40.5Graphics 2D - Complex Vectors8982.8Graphics 2D - Fonts and Text46.483.5Graphics 2D - Windows Interface29.247.4Graphics 2D - Image Filters48.1822D Graphics - Image Rendering81.1158.7Graphics 3D - Simple126.1126Graphics 3D - Medium53.452.8Graphics 3D - Complex14.616.3Graphics 3D - DirectX 101.21.2Memory - Allocate Small Block1108.72054.5Memory - Read Cached348.6669.5Memory - Read Uncached319.6597.2Memory - Write354593.3Memory - Large RAM386.1664.3Disk - Sequential Read28.672.5Disk - Sequential Write68.472.3Disk - Random Seek + RW2.63.7CPU Mark2031.32571.12D Graphics Mark103.8140.2Memory Mark221.4394Disk Mark360.1537.23D Graphics Mark123.5126.9PassMark Rating434.3590.2
    The other thing is integer math score for AMD Phenom II processor seems very low 300 to 400 anybady know why is that?
    thanks in advance
    See this old post.
    My guess would be that you are running the 32bit release of PerformanceTest on your 64bit O/S.
    If you have 64bit Windows you should try and use 64bit software.
    See also this old post,
    Q9300 Stock Clock, Low Math Integer Score
    • priyantha
      • Mar 2011
      Thanks for quick reply. I am using 64 bit version. Here is result from latest test
      PassMark(TM) PerformanceTest 7.0 Evaluation Version (http://www.passmark.com)
      Results generated on: Tuesday, March 22, 2011
      Benchmark Results
      Test Name: This Computer
      CPU - Integer Math: 236.2
      CPU - Floating Point Math: 1278.1
      CPU - Find Prime Numbers: 420.9
      CPU - SSE: 7.8
      CPU - Compression: 2080.8
      CPU - Encryption: 9.7
      CPU - Physics: 127.8
      CPU - String Sorting: 1687.4
      Graphics 2D - Solid Vectors: 0.4
      Graphics 2D - Transparent Vectors: 0.4
      Graphics 2D - Complex Vectors: 88.4
      Graphics 2D - Fonts and Text: 48.0
      Graphics 2D - Windows Interface: 27.6
      Graphics 2D - Image Filters: 48.1
      2D Graphics - Image Rendering: 84.4
      Graphics 3D - Simple: 125.9
      Graphics 3D - Medium: 53.4
      Graphics 3D - Complex: 14.5
      Graphics 3D - DirectX 10: 1.2
      Memory - Allocate Small Block: 1200.2
      Memory - Read Cached: 367.6
      Memory - Read Uncached: 342.0
      Memory - Write: 469.9
      Memory - Large RAM: 442.1
      Disk - Sequential Read: 71.6
      Disk - Sequential Write: 70.3
      Disk - Random Seek + RW: 3.7
      CPU Mark: 1907.4
      2D Graphics Mark: 104.1
      Memory Mark: 251.8
      Disk Mark: 526.8
      3D Graphics Mark: 123.2
      PassMark Rating: 461.3
      CPU Manufacturer: AuthenticAMD
      Number of CPU: 1
      Cores per CPU: 4
      CPU Type: AMD Phenom II N930 Quad-Core
      CPU Speed: 1995.5 MHz
      Cache size: 512KB
      O/S: Windows 7 (64-bit)
      Total RAM: 3834.9 MB.
      Available RAM: 2573.3 MB.
      Video settings: 1366x768x32
      Video driver:
      DESCRIPTION: ATI Mobility Radeon HD 4200 Series
      MANUFACTURER: ATI Technologies Inc.
      BIOS: BK-ATI VER010.094.001.045.035812
      DATE: 1-26-2011
      Drive Letter: C
      Total Disk Space: 445.1 GBytes
      Cluster Size: 4.0 KBytes
      File system: NTFS
      I comaired this with following baseline from passmark.com
      HP Pavilion dv6-3013 AMD Phenom II N930 Quad-Core 1995 Laptop BL369466thanks
        Check that you are both running on mains power and that the laptop isn't running in a power saving mode.
        • priyantha
          • Mar 2011
          Thanks for that instruction. I was using Power Saver Mode. Scores increased after changing to High Performance mode. As follows
          Results generated on: Wednesday, March 23, 2011
          Benchmark Results
          CPU - Integer Math: 403.2
          CPU - Floating Point Math: 2019.4
          CPU - Find Prime Numbers: 553.3
          CPU - SSE: 10.4
          CPU - Compression: 2778.6
          CPU - Encryption: 12.4
          CPU - Physics: 162.7
          CPU - String Sorting: 2031.9
          Graphics 2D - Solid Vectors: 0.6
          Graphics 2D - Transparent Vectors: 0.6
          Graphics 2D - Complex Vectors: 87.7
          Graphics 2D - Fonts and Text: 95.1
          Graphics 2D - Windows Interface: 62.5
          Graphics 2D - Image Filters: 114.8
          2D Graphics - Image Rendering: 200.7
          Graphics 3D - Simple: 129.5
          Graphics 3D - Medium: 54.6
          Graphics 3D - Complex: 17.2
          Memory - Allocate Small Block: 2336.0
          Memory - Read Cached: 875.5
          Memory - Read Uncached: 803.9
          Memory - Write: 878.6
          Memory - Large RAM: 941.9
          Disk - Sequential Read: 71.2
          Disk - Sequential Write: 71.6
          Disk - Random Seek + RW: 4.1
          CPU Mark: 2633.5
          2D Graphics Mark: 170.7
          Memory Mark: 527.5
          Disk Mark: 531.5
          3D Graphics Mark: 131.3
          PassMark Rating: 665.6
          Number of CPU: 1
          Cores per CPU: 4
          CPU Speed: 1995.2 MHz
          Cache size: 512KB
          Available RAM: 2377.7 MB.
          Video driver:
          DATE: 1-26-2011
          Drive Letter: C
          File system: NTFS
          cheers!
