Saving settings on exit
  • videobruce
    How do you save settings on exit?
    Espercially under the advanced/3d graphics test.
    The; select all, rendering mode, number of objects and textures I wouls like to change to max out everything.
    I looked throught the registry using Reg Crawler, but can't find any entries under Passmark or Preformance Test.
    The current version of the software doesn't save most of its settings. Each time the program is started the default values are used.
    You need to reselect your settings each time you go back into the 3D window.
    PassMark
    • videobruce
      Thaks you the reply.
      Ok, where in the registry are the default settings stored so they could be edited?
      It's a nice program, especially just to test FPS as oppose to some meaningless 3 or 4 digit number that really doesn't mean anything, but it is a pain to change all of that everytime especially when you are 'tweaking' your system and have to run mulitple tests.
      • ferg
        • 12
        Unfortunately in this version of PerformanceTest, all Advanced Test default settings are hard coded (including the Graphics test). We will address this shortcoming in a future release.
        Fergus Deffely,
        PassMark Software
        Fergus Deffely,
        PassMark Software
