VGA issue - very low performance
  • ultimavn
    • Jul 2011
    Last week my pc just decided to stop working so I brought it to the repair center. I try playing some games after I got it back and the result is abysmal. FPS was like single digit on everything so I decide to try using passmark and here's the test result
    PassMark(TM) PerformanceTest 7.0 Evaluation Version (http://www.passmark.com)
    Results generated on: Saturday, July 16, 2011
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 826.1
    CPU - Floating Point Math: 1267.1
    CPU - Find Prime Numbers: 618.4
    CPU - SSE: 5.1
    CPU - Compression: 2878.0
    CPU - Encryption: 8.2
    CPU - Physics: 159.3
    CPU - String Sorting: 1665.6
    Graphics 2D - Solid Vectors: 0.6
    Graphics 2D - Transparent Vectors: 0.6
    Graphics 2D - Complex Vectors: 96.9
    Graphics 2D - Fonts and Text: 56.4
    Graphics 2D - Windows Interface: 40.1
    Graphics 2D - Image Filters: 130.0
    Graphics 2D - Image Rendering: 326.7
    Graphics 3D - Simple: 67.9
    Graphics 3D - Medium: 28.6
    Graphics 3D - Complex: 7.2
    Graphics 3D - DirectX 10: 0.7
    Memory - Allocate Small Block: 3465.6
    Memory - Read Cached: 2349.6
    Memory - Read Uncached: 2131.0
    Memory - Write: 1691.5
    Memory - Large RAM: 1749.5
    Disk - Sequential Read: 64.8
    Disk - Sequential Write: 58.6
    Disk - Random Seek + RW: 3.1
    CPU Mark: 2357.6
    2D Graphics Mark: 170.9
    Memory Mark: 1034.0
    Disk Mark: 457.2
    3D Graphics Mark: 66.4
    PassMark Rating: 547.1
    Number of CPU: 1
    Cores per CPU: 2
    CPU Type: Intel Core2 Duo E8200 @ 2.66GHz
    CPU Speed: 2667.1 MHz
    Cache size: 6144KB
    O/S: Windows 7 (64-bit)
    Total RAM: 4094.5 MB.
    Available RAM: 2805.6 MB.
    Video settings: 1280x1024x32
    Video driver:
    DESCRIPTION: NVIDIA GeForce 9800 GT
    MANUFACTURER: NVIDIA
    BIOS: Version 62.92.23.0.10
    DATE: 5-20-2011
    Drive Letter: C
    Total Disk Space: 49.0 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    I'm using 7.0 build 1022 64-bit.
    Anything looks okay, except for the 2D and 3D Graphic Mark. While the 2D Mark is equal to 1/2 of other of the same model, which is somewhat acceptable, The 3D Mark is like 1/10 to 1/30. I suspect my VGA got swap but I wanna be sure before taking measures so here I am posting question.
    Sadly I don't know much about hardware so would someone kindly explain in full details for me on this matter?
    Thanks in advance.
    Check the right video card device driver is installed.
    See also this post,
    • ultimavn
      • Jul 2011
      all 3 acceleration were checked from the start and I already try 3 different driver , very small different
