Help understanding one poor test result
  • KingCapybara
    • Jul 2011
    Hello I can a fairly new PC that seems to be running slow and have tried everything to diagnose it. I have run Performance Test and compared the test results and nearly every test seems to be on par with similar systems except one.
    My Small Block Memory test yielded a 214.6 nearly 700%+ lower than the lowest system of comparable specs. Can anyone tell me what would cause this, bad chip, system config, etc. or should I move on to some other factor?
    My system: XP Pro SP3, Intel Core 2 Quad CPU Q8300 @ 2.50GHz, Memory is two DDR2, 2048MB 800MHZ.
    • 11114
    Yes, 214.6 is a very low number.
    Did you run it a few times to see if it was a one off.
    Can you post the rest of the results.
    Have you checked the CPU temperature when under load?
    • KingCapybara
      • Jul 2011
      Here are some more test results in text form, I can upload more if needed. I ran it several times, and the CPU temp seems within range.
      Test Name: This Computer
      CPU - Integer Math: 478.0
      CPU - Floating Point Math: 1818.9
      CPU - Find Prime Numbers: 1026.3
      CPU - Multimedia Instructions: 8.5
      CPU - Compression: 5638.4
      CPU - Encryption: 15.8
      CPU - Physics: 188.4
      CPU - String Sorting: 2499.7
      Memory - Allocate Small Block: 226.1
      Memory - Read Cached: 1935.3
      Memory - Read Uncached: 1816.9
      Memory - Write: 1787.3
      Memory - Large RAM: 928.4
      CPU Mark: 3072.7
      Memory Mark: 636.4
      PassMark Rating: 1146.9
      Number of CPU: 1
      Cores per CPU: 4
      CPU Type: Intel Core2 Quad Q8300 @ 2.50GHz
      CPU Speed: 2493.9 MHz
      Cache size: 2048KB
      O/S: Windows XP (32-bit)
      Total RAM: 3071.2 MB.
      Available RAM: 2158.4 MB.
      Video settings: 1920x1080x32
      Video driver:
      DESCRIPTION: NVIDIA GeForce GT 240
      MANUFACTURER:
      BIOS: Version 70.15.45.00.76
      DATE:
      Drive Letter: C
      Total Disk Space: 596.2 GBytes
      Cluster Size: 4.0 KBytes
      File system: NTFS
        • 11114
        Yes, the other results look pretty much normal.
        Your problem might be this issue here,
        http://www.passmark.com/forum/showth...?t=2649&page=2
        (maybe there is some software on your system interfering with the zero-page thread background task)
